It seems like the API-generated drawing's scale is based on the original floor plan scale.
The attached picture is a screenshot of the lower-right of the floor plan and the same API-generated drawing. They are of the same scale.
Now, how to set this API-generated drawing to the same scale as the first post (the detail's scale) is still unknown [to me, at least].
EDIT
Is there a way to set the
API_DrawingType.drawingScale (Drawing Scale in Properties) and/or
API_DrawingType.parentOriginalScale (Original Scale in Properties) before creating the drawing element (
ACAPI_Element_Create())?
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
