export obj
hey, i try to write a script which export floors automatic to obj files,
can you please direct me what to learn from the api devkit?
3 Replies 3
Can you clarify your request a bit? Do you want to save the 3D model as a WaveFront (.obj) file? If so, this is already included in ArchiCAD.
If you mean something else, please explain in greater detail.
Ralph Wessel BArch
Central Innovation
what i am trying to do is making a button which save each floor as an obj file in a local folder, this mean that it isolate every floor at a time and save it, and the result is that i have one button that export me all the floors in one click.
Akos Somorjai
You can switch between stories with APIEnv_ChangeStorySettingsID, then enumerate all elements there with ACAPI_Element_Filter(). After that, for 2D export you can use ACAPI_Element_ShapePrims, and for 3D export ACAPI_Element_Get3DInfo and its friends.
Hope this helps,
Akos
