how to let the user stop a for-loop (DGModelessHandler?)
Hi!
I am searching for a way to enable the user to stop a for-loop started by the addon.
Example:
   bool abort = false;
   CTestWindow window(abort); //modeless window with access to "abort"
   for (int i = 0; (i < 10) && !abort; i++)
      Sleep(500);
      PRINT(GET(i));
The user should be able to stop the for-loop via the created modeless-window.
But the window is not responding during the for-loop.
I tried to use the objectorientated way (inheriting or using DG::ModelessDialog) and the old way
(using DGCreateBlankModelessDialog, DGBeginProcessEvents, ...).
I found the docu of "DGModelessHandler" which i do not understand.
This method seems to belong to the 'old way'.
In the docu there is a passage which describes the scenario i am facing:
> The usage of the dialog status flag can be explain by the following
> example. Suppose that an application begins a long process such as a
> time-consuming calculation. In this case, it is advisable to show a
> process indicator dialog with a Stop button until the calculation is
> finished. When handling system-specific messages during this period,
> you should call DGModelessHandler with onlyUpdate of value true. This
> ensures that modeless dialogs of DG_DS_NORMAL state do not handle any
> messages except the update messages (this way they do not respond to
> any user actions). The status of the process indicator dialog should
> be set to DG_DS_ENABLED in order to enable the user to press the Stop
> button and cancel the process.
But i have no idea how to use "DGModelessHandler" 😞
It seems that this method does not belong into the code of an Addon:
> Call this function just after receiving a system-specific message
> in the application's message loop.
This method is used in the following file of the api-examples:
"...\API Development Kit 5\Examples\DGTest\Sources.win\DGTestWin.cpp"
This does not look like an Addon but like an application.
Hmm, very strange.
I hope someone has a hint how to start a modeless dialog which keeps responding.
I would prefer the object orientated way using the class DG::ModelessDialog.
Perhaps there is a ArchiCad-way to use threads?
The process-window which could be created with "ACAPI_Interface(APIIo_InitProcessWindowID,.." does not seem to work properly.
regards,
John
4 Replies 4
Akos Somorjai
Hello John,
Try to use a palette instead. Modeless dialogs are special to ArchiCAD.
To make the loop breakable try calling something like DGGetMousePosition inside the loop; that lets other event handlers run.
The example you are referring to is the test application for the Dialog Manager (a.k.a DG) module.
HTH,
Akos
Hi Akos 🙂
Ok, now my test class creates a palette the old way (DGCreateBlankPalette) and looks like that:
class CTest3Window
   public:
      CTest3Window(); //creates a pallette with "DGCreateBlankPalette"
      ~CTest3Window();
      void live(); //invokes "DGGetMousePosition"
      static short int DGCALLBACK mainEventHandler(
         short  message,
         short  dialId,
         short  itemId,
         long   userData,
         long   msgData
   private:
      short mDialogId;
   CTest3Window::CTest3Window()
      mDialogId = DGCreateBlankPalette   (
         200,                   //   hSize,
         200,                   //   vSize,
         DG_DLG_NOGROW,         //   growFlag,
         DG_DLG_CLOSE,          //   closeFlag,
         0,                     //   captionFlag,
         DG_DLG_NORMALFRAME,    //   frameFlag,
         this->mainEventHandler,//   dCallBack,
         0                      //userData
      DGShowModelessDialog(mDialogId);
      DGBeginProcessEvents(mDialogId);
      DGSetModelessDialogStatus(mDialogId, DG_DS_ENABLED);
   CTest3Window::~CTest3Window()
      DGEndProcessEvents(mDialogId);
      DGDestroyModelessDialog(mDialogId);
   void CTest3Window::live()
      DGMousePosData mpd;
      short mouseStatus = DGGetMousePosition(mDialogId, &mpd);
In CTest3Window::live() I invoke "DGGetMousePosition" and the for loop looks like that:
  window.live(); //invokes "DGGetMousePosition"
  Sleep(500);
The eventhandler assigned to the palette is still not invoked during the for-loop 😞
I tried the the same going the object-orientated way using DG::Palette, but the attached Event-Observer is not notified neither.
Yes, this does not seem to be an addon.
Do you have an idea how to use DGModelessHandler in a normal addon?
Greeting,
John
Hi 🙂
Now, I am using "APIIo_InitProcessWindowID" after all...
It takes a long time before the process-window appears.
So if the process does not takes long enough you don't see this window. Thats why i thought it would not work.
bool abort = false;
short nPhase = 1;
long maxval = 100;
ACAPI_Interface (APIIo_InitProcessWindowID, "incremental search", &nPhase);
ACAPI_Interface (APIIo_SetNextProcessPhaseID, "working...", &maxval);
for (int i = 0; (i < maxval) && !abort; i++)
   Sleep(500);
   PRINT(GET(i));
   ACAPI_Interface(APIIo_SetProcessValueID, &i, NULL);
   if (ACAPI_Interface(APIIo_IsProcessCanceledID, NULL, NULL))
      abort = true;
ACAPI_Interface (APIIo_CloseProcessWindowID, NULL, NULL);
[Threads]
An other way i tried was the following:
I coded a Status-Window which is able to invoke the method whose status is to be monitored in a new thread.
But there were several problems:
1. The thread I used is not OS-independent and I think you should avoid OS-specific code in AC-Addons.
2. ArchiCAD often crashes, if the method running in the thread is selecting elements or changing the AC-database.
But perhaps someone still has a hint how to start a window which keeps reacting while an other method is working.
cu,
John
Ralph Wessel
John,
The API process window has a built-in delay before appearing, which unfortunately cannot be modified. The delay is far too long in my opinion - a user could easily think the software has crashed.
John wrote:
[Threads]
The crux of the problem is that much of ArchiCAD has not been designed to support threading. That's why it crashes when a separate thread attempts to access the database.
Ralph Wessel BArch
Central Innovation
