I've moved this thread into the Developer Forum where it belongs.
Karl (in moderator mode)
But, in response, this can be done either via GDL - in which case the model would be a single monolithic GDL object when finished - or via the API in which case individual building elements can be created.
Personally, I would think it could make more sense to write a script that converts the XML into an IFC file?
Karl (in member mode)
AC 28 USA and earlier • macOS Sequoia 15.3, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
