Kaspars
polylines with radius
Hi, i'm quite new to GDL and
can somebody guide me on how to insert line segment with defined radius into POLY2 command.
All i can do is - insert node's x,y coordinates to draw stright lines, but I know there is a way to add curved ones too, i just don't know how 🙂
Thx a lot,
Kaspars
1 Solution
Depends on what kind of arc you want to place.
It could be tangential from the last line segment, it could have an endpoint and a radius, it could have a centre point and a radius, and there are other versions as well.
Have a look in the GDL reference guide and look for the section on 'Status codes' and then go to the section for 'Additional status codes'.
Best is to drawer the shape (polyline) you want with one point on the project origin.
Then select polyline and go to FILE menu > Libraries and Objects > Save Selection as Library Part > Object.
Place the object, select it and open the script.
Have a look at the script to see what it has automatically written.
This might help you to understand.
It will probably only use this 4000 status code - start point, center point and rotation angle.
Go to post
2 Replies 2
Kaspars
Yes,
thank You very much,
forgot about Special  tatus codes.
My bad, didn't read GDL reference guide closely enough. Sometimes getting lost there
Kaspars
