question about getting an element's attribute
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2018-02-09
11:16 AM
‎2023-07-12
05:50 PM
Doreena Deng
‎2018-02-09
11:16 AM
Hello Archicad developers!
I have a little trouble with getting the names of each element's composite. The issue is that each time I cycle through my elements it returns the first element's composite name. I suspect that I don't use the ACAPI_Element_Get function in the right way.
Here is part of my code:
API_Element element; vector <elementsList> eL; GS::Array<API_ElemTypeID> typeIDs = {API_WallID, API_SlabID, API_RoofID}; // the types we are going to look for for(int i=0; i < typeIDs.GetSize(); i++){ GS::Array<API_Guid> elemListGuid; ACAPI_Element_GetElemList (typeIDs, &elemListGuid); // get the elements for each type for(int k=0; k < elemListGuid.GetSize(); k++){ WriteReport("element number %i", k); GSErrCode err2; BNZeroMemory (&element, sizeof (API_Element)); element.header.typeID = typeIDs; element.header.guid = elemListGuid.Get(k); // GUID OF EACH ELEMENT err2 = ACAPI_Element_Get (&element); // GETTING THE ELEMENT ??? if (err2 != NoError) { WriteReport_Alert ("Unknown element"); return; } else{ // we have element! } API_Attribute attrib; GSErrCode err3; BNZeroMemory (&attrib, sizeof (API_Attribute)); attrib.header.typeID = API_CompWallID; attrib.header.index = element.header.layer + 1; err3 = ACAPI_Attribute_Get (&attrib); if (err3 == NoError){ WriteReport_Alert("BINGO!! name is %s", attrib.header.name); // HERE IT ALWAYS PRINTS THE FIRST ELEMENT COMPOSITE NAME... } } }
Labels:
- Labels:
Add-On (C++)
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-02-09 02:43 PM
‎2018-02-09
02:43 PM
I have resolved this. The problem was that I was passing the element layer index, instead of the composite one. This was my solution:
if(typeIDs == API_WallID){ // Its a wall compIndex = element.wall.composite; } if(typeIDs == API_SlabID){ // Its a slab compIndex = element.slab.composite; } if(typeIDs == API_RoofID){ // Its a roof compIndex = element.roof.shellBase.composite; }
