ReignBough
Offset all edges of a polygon/polyarc.
Previously known as: PGPolyPositionExt crashes.
Geometry::PGRelPolyPosExt pos = Geometry::UnknownStatus;
g_PolyArc_LastError = Geometry::PGPolyPositionExt(&polyExt1, &polyExt2, &pos);
Both polyExt1 and polyExt2 are derived from memo:
memo to Polygon2DData: (from Element_Snippents.cpp)
static GSErrCode	ConstructPoly2DDataFromElementMemo (const API_ElementMemo& memo, Geometry::Polygon2DData& polygon2DData)
	GSErrCode err = NoError;
	Geometry::InitPolygon2DData (&polygon2DData);
	static_assert (sizeof (API_Coord) == sizeof (Coord), "sizeof (API_Coord) != sizeof (Coord)");
	static_assert (sizeof (API_PolyArc) == sizeof (PolyArcRec), "sizeof (API_PolyArc) != sizeof (PolyArcRec)");
	polygon2DData.nVertices = BMGetHandleSize (reinterpret_cast<GSHandle> (memo.coords)) / sizeof (Coord) - 1;
	polygon2DData.vertices = reinterpret_cast<Coord**> (BMAllocateHandle ((polygon2DData.nVertices + 1) * sizeof (Coord), ALLOCATE_CLEAR, 0));
	if (polygon2DData.vertices != NULL)
		BNCopyMemory (*polygon2DData.vertices, *memo.coords, (polygon2DData.nVertices + 1) * sizeof (Coord));
	else
		err = APIERR_MEMFULL;
	if (err == NoError && memo.parcs != NULL) {
		polygon2DData.nArcs = BMGetHandleSize (reinterpret_cast<GSHandle> (memo.parcs)) / sizeof (PolyArcRec);
		if (polygon2DData.nArcs > 0) {
			polygon2DData.arcs = reinterpret_cast<PolyArcRec**> (BMAllocateHandle ((polygon2DData.nArcs + 1) * sizeof (PolyArcRec), ALLOCATE_CLEAR, 0));
			if (polygon2DData.arcs != NULL)
				BNCopyMemory (*polygon2DData.arcs + 1, *memo.parcs, polygon2DData.nArcs * sizeof (PolyArcRec));
			else
	if (err == NoError) {
		polygon2DData.nContours = BMGetHandleSize (reinterpret_cast<GSHandle> (memo.pends)) / sizeof (Int32) - 1;
		polygon2DData.contourEnds = reinterpret_cast<UIndex**> (BMAllocateHandle ((polygon2DData.nContours + 1) * sizeof (UIndex), ALLOCATE_CLEAR, 0));
		if (polygon2DData.contourEnds != NULL)
			BNCopyMemory (*polygon2DData.contourEnds, *memo.pends, (polygon2DData.nContours + 1) * sizeof (UIndex));
		else
		Geometry::GetPolygon2DDataBoundBox (polygon2DData, &polygon2DData.boundBox);
		polygon2DData.status.isBoundBoxValid = true;
	} else {
		Geometry::FreePolygon2DData (&polygon2DData);
	return err;
}		// ConstructPoly2DDataFromElementMemo
Polygon2DData to PGPOLYEXT: (from: Post #212330)
GSErrCode Convert_Polygon2DData_To_PGPOLYEXT (const Geometry::Polygon2DData&    polygon2DData,
                                                Geometry::PGPOLYEXT*         pgPOLYEXT)
   if (&polygon2DData == NULL)
      return ErrParam;
   BNZeroMemory (pgPOLYEXT, sizeof (Geometry::PGPOLYEXT));
   // here comes a little bit ugly cast
   pgPOLYEXT->data = reinterpret_cast<GSPtr> (const_cast<Geometry::Polygon2DData*> (&polygon2DData));
   // Perhaps you need to set some other attributes too:
   //  pgPOLYEXT->status.isSameDirEdgeLegal = polygon2DData.status.isSameDirEdgeLegal;
   //  pgPOLYEXT->epsilon = SMALLEPS * 8;
   //  pgPOLYEXT->minVertexDist = 3 * pgPOLYEXT->epsilon;
   return NoError;
The crash is for some instances only. I tested it in a small test model, it works. But when I tested on large test model, it crashes. When I skipped the slab polygons that cause the crash (on debug mode), it is okay.
EDIT 1: (2018 Feb 23)
Found what causes the crash. It is when i called OffsetPolygon2DDataEdge() function to adjust the main polygon. When I removed this code, it does not crash anymore. It probably beacuse I adjust one edge at a time.
What I need now is a function the same as this but adjust all the edges all at once. Is there such thing? Like this:
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
0 Replies 0
