Offset all edges of a polygon/polyarc.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2018-02-07
10:33 AM
2023-07-12
05:51 PM
Doreena Deng
2018-02-07
10:33 AM
Geometry::PGRelPolyPosExt pos = Geometry::UnknownStatus; g_PolyArc_LastError = Geometry::PGPolyPositionExt(&polyExt1, &polyExt2, &pos);Both polyExt1 and polyExt2 are derived from memo:
memo to Polygon2DData: (from Element_Snippents.cpp)
static GSErrCode ConstructPoly2DDataFromElementMemo (const API_ElementMemo& memo, Geometry::Polygon2DData& polygon2DData) { GSErrCode err = NoError; Geometry::InitPolygon2DData (&polygon2DData); static_assert (sizeof (API_Coord) == sizeof (Coord), "sizeof (API_Coord) != sizeof (Coord)"); static_assert (sizeof (API_PolyArc) == sizeof (PolyArcRec), "sizeof (API_PolyArc) != sizeof (PolyArcRec)"); polygon2DData.nVertices = BMGetHandleSize (reinterpret_cast<GSHandle> (memo.coords)) / sizeof (Coord) - 1; polygon2DData.vertices = reinterpret_cast<Coord**> (BMAllocateHandle ((polygon2DData.nVertices + 1) * sizeof (Coord), ALLOCATE_CLEAR, 0)); if (polygon2DData.vertices != NULL) BNCopyMemory (*polygon2DData.vertices, *memo.coords, (polygon2DData.nVertices + 1) * sizeof (Coord)); else err = APIERR_MEMFULL; if (err == NoError && memo.parcs != NULL) { polygon2DData.nArcs = BMGetHandleSize (reinterpret_cast<GSHandle> (memo.parcs)) / sizeof (PolyArcRec); if (polygon2DData.nArcs > 0) { polygon2DData.arcs = reinterpret_cast<PolyArcRec**> (BMAllocateHandle ((polygon2DData.nArcs + 1) * sizeof (PolyArcRec), ALLOCATE_CLEAR, 0)); if (polygon2DData.arcs != NULL) BNCopyMemory (*polygon2DData.arcs + 1, *memo.parcs, polygon2DData.nArcs * sizeof (PolyArcRec)); else err = APIERR_MEMFULL; } } if (err == NoError) { polygon2DData.nContours = BMGetHandleSize (reinterpret_cast<GSHandle> (memo.pends)) / sizeof (Int32) - 1; polygon2DData.contourEnds = reinterpret_cast<UIndex**> (BMAllocateHandle ((polygon2DData.nContours + 1) * sizeof (UIndex), ALLOCATE_CLEAR, 0)); if (polygon2DData.contourEnds != NULL) BNCopyMemory (*polygon2DData.contourEnds, *memo.pends, (polygon2DData.nContours + 1) * sizeof (UIndex)); else err = APIERR_MEMFULL; } if (err == NoError) { Geometry::GetPolygon2DDataBoundBox (polygon2DData, &polygon2DData.boundBox); polygon2DData.status.isBoundBoxValid = true; } else { Geometry::FreePolygon2DData (&polygon2DData); } return err; } // ConstructPoly2DDataFromElementMemoPolygon2DData to PGPOLYEXT: (from: Post #212330)
GSErrCode Convert_Polygon2DData_To_PGPOLYEXT (const Geometry::Polygon2DData& polygon2DData, Geometry::PGPOLYEXT* pgPOLYEXT) { if (&polygon2DData == NULL) return ErrParam; BNZeroMemory (pgPOLYEXT, sizeof (Geometry::PGPOLYEXT)); // here comes a little bit ugly cast pgPOLYEXT->data = reinterpret_cast<GSPtr> (const_cast<Geometry::Polygon2DData*> (&polygon2DData)); // Perhaps you need to set some other attributes too: // pgPOLYEXT->status.isSameDirEdgeLegal = polygon2DData.status.isSameDirEdgeLegal; // pgPOLYEXT->epsilon = SMALLEPS * 8; // pgPOLYEXT->minVertexDist = 3 * pgPOLYEXT->epsilon; return NoError; }The crash is for some instances only. I tested it in a small test model, it works. But when I tested on large test model, it crashes. When I skipped the slab polygons that cause the crash (on debug mode), it is okay.
EDIT 1: (2018 Feb 23)
Found what causes the crash. It is when i called OffsetPolygon2DDataEdge() function to adjust the main polygon. When I removed this code, it does not crash anymore. It probably beacuse I adjust one edge at a time.
What I need now is a function the same as this but adjust all the edges all at once. Is there such thing? Like this:
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
Labels:
- Labels:
Add-On (C++)
0 REPLIES 0
