nishida_jp
How to change the edge settings (line color and thickness) of a 3D(Model) slab in ArchiCAD 27 using
How to change the edge settings (line color and thickness) of a 3D(Model) slab in ArchiCAD 27 using the C++ API
Hiromichi Shinkawa
Hi, if you'd change the slab outline color (2D/3D), then the parameter is element.slab.pen.
HTH.
