2018-01-18
01:02 PM
- last edited on
2022-12-06
01:45 PM
by
Daniel Kassai
GSErrCode __ACENV_CALL RegisterInterface(void)
GSErrCode err;
// Register menus
//err = ACAPI_Register_Menu (32500, 0, MenuCode_UserDef, MenuFlag_SeparatorBefore);
err = ACAPI_Register_Menu(32500, 0, MenuCode_Palettes, MenuFlag_SeparatorBefore);
return err;
} /* RegisterInterface */
// Called when the Add-On has been loaded into memory
// to perform an operation
GSErrCode __ACENV_CALL Initialize(void)
GSErrCode err = NoError;
static short result = 0;
// Install menu handler callbacks
err = ACAPI_Install_MenuHandler(32500, MenuCommandHandler);
return err;
//return err;
} /* Initialize */
// Called when the Add-On is going to be unloaded
GSErrCode __ACENV_CALL FreeData(void)
return NoError;
} /* FreeData */
2018-01-18 03:14 PM
jcimentarov wrote:Are you calling
I have developed a plugin for Archicad 21. It has a pallette with buttons. I have made it to be reachable through window->pallette. When I open the pallette and close the whole Archicad it just crashes and opens the bug report. What could be the possible reason for the whole archicad to crash when I try to close it with my plugin opened?
2018-01-22 09:53 AM
2018-01-22 10:21 AM
jcimentarov wrote:The documentation for
I have tried putting ACAPI_KeepInMemory(1) in Initialize() and MenuCommandHandler(), but it stills crashes if I have the palette opened and quit ARCHICAD.
By the way I have developed this plugin for both MAC and Windows and this only happens on the windows version of the plugin.
Am I placing the ACAPI_KeepInMemory() on the right place?
You should call this function with true each time your add-on is called to stay in memory. The values of all your global variables stay the same between the calls to your add-on. Also, when in memory, the Initialize and the FreeData functions of your add-on are not called. See more about this topic at the Control the Load/Unload Mechanism part of the Tips and Tricks.If that's taken care of, then there must be another explanation for the crash. Are there any other clues, e.g. crash report or a stack trace? Are you able to debug into the point where it crashes? It's most likely to be an issue with memory management.
2018-01-22 03:20 PM
'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Visualisation\OpenGL Engine.gmx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Windows\System32\prl_umdd10.dll' The thread 0x1058 has exited with code 0 (0x0). The thread 0x17f8 has exited with code 0 (0x0). The thread 0x152c has exited with code 0 (0x0). Exception thrown at 0x00007FF93C123FB8 in ARCHICAD.exe: Microsoft C++ exception: GS::InterruptedException at memory location 0x000000F9E73FF658. The thread 0x1184 has exited with code 0 (0x0). The thread 0x1fc0 has exited with code 0 (0x0). The thread 0xdc4 has exited with code 0 (0x0). Exception thrown at 0x00007FF93C123FB8 in ARCHICAD.exe: Microsoft C++ exception: GS::InterruptedIOException at memory location 0x000000F9E74FC160. Exception thrown at 0x00007FF93C123FB8 in ARCHICAD.exe: Microsoft C++ exception: GS::InterruptedIOException at memory location 0x000000F9E74FD868. Exception thrown at 0x00007FF93C123FB8 in ARCHICAD.exe: Microsoft C++ exception: [rethrow] at memory location 0x0000000000000000. Exception thrown at 0x00007FF93C123FB8 in ARCHICAD.exe: Microsoft C++ exception: GS::InterruptedIOException at memory location 0x000000F9E74FD868. The thread 0xae0 has exited with code 0 (0x0). 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Environment_Control.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Standard\Selections.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Standard\RegisterLightworksFileTypes.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Standard\Quick Layers.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Standard\NecessaryLPs.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Standard\Interactive Schedule.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Standard\Element Information.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Standard\Corner Window.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Standard\Active Layer.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Standard\3Dconnexion Enabler.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\MEP.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\MEP Modeler\MEP Modeler.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Local\Grid Tool.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Import-Export\Rhino_Out.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\opennurbs.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Import-Export\Rhino_In.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\EXPRESSManagerUtilities_EDM.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Ifc2x3Classes_EDM.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9317_none_08e0939fa840d57b\msvcr90.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\edm_libxml2.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\edmikit500.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\EDM.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Ifc4Classes_EDM.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\IfcCommonClasses_EDM.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Import-Export\IFC.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Import-Export\CommonBlock.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Import-Export\CorrectTextPos.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Import-Export\LabelIO.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Import-Export\MeshIn.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Import-Export\PointIN.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Import-Export\RoundTrip.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\ZLib-DWG.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\PlotStyleServices-DWG_4.01src_14.tx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\TD_Gs-DWG_4.01src_14.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\DWFToolkit-DWG.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\W3dTk-DWG.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\WhipTk-DWG.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\DWFCore-DWG.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\TD_Dwf7Export-DWG_4.01src_14.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\DXF_DWG_Engine.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\TD_DbRoot-DWG_4.01src_14.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\TD_Gi-DWG_4.01src_14.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\TD_SpatialIndex-DWG_4.01src_14.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\TD_Db-DWG_4.01src_14.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\sisl-DWG.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\TD_Ge-DWG_4.01src_14.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\TD_Alloc-DWG_4.01src_14.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\TD_Root-DWG_4.01src_14.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Import-Export\DXF-DWG In-Out.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Extras\Profile Database.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Extras\MeshImport.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Windows\System32\Wldap32.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Extras\ARCHICAD Online Training.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\EnergyEvaluation.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\LibXL.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\EnergyEvaluation\EnergyEvaluation.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Windows\System32\msvcr120.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\PVRTexLib.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\LibXML.dll' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\BIMx\BIMx.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Import-Export\Collada In-Out.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Import-Export\GoogleEarthConnectivity.apx' 'ARCHICAD.exe' (Win32): Unloaded 'C:\Program Files\GRAPHISOFT\ARCHICAD 21\Add-Ons\Import-Export\PointCloud_In.apx' The thread 0x154c has exited with code 0 (0x0). The thread 0xc60 has exited with code 0 (0x0). The thread 0x550 has exited with code 0 (0x0). 'ARCHICAD.exe' (Win32): Unloaded 'C:\Windows\System32\mfreadwrite.dll' Exception thrown at 0x00007FF8F8DD5FD0 in ARCHICAD.exe: 0xC0000005: Access violation executing location 0x00007FF8F8DD5FD0.
2018-01-22 04:19 PM
2018-01-23 10:33 AM
DGDestroyPalette(myDialID);
return NoError;
