GDL
Archicad crashes while making object
lmcardoso
We do a lot of static objects in the 2d symbol menu using the fragment2 command to place multiple options in 1 object.
But if i have multiple 2d element types selected and try to change the layer of all using the Edit selection set tool archicad crashes.
would be great to have this fixed
ArchiCAD 23/25/27 with Win 10
1 REPLY 1
Have you reported this to your local Archicad support people?
If they don't know about it, nothing will get done.
Reporting it here does not mean it will be noticed by Graphisoft.
You might get others confirm the problem or offer workarounds.
But it really needs to be investigated by your local support and then if there is an issue they can pass it on to GSHQ.
Setup info provided by author
