JGoode
Using Bottom Offset to Home Story within object
Hello,
I was trying to use a parameter within my object interface to control the height of my object. I would like this value to automatically reflect in the object elevation fields within the "Preview and Positioning" section of the "Object Selection Settings". Is this possible to do?
Thanks
ArchiCAD 27
Windows 10
Peter Baksa
Hi JGoode,
yes, set ac_bottomlevel and ac_toplevel in the parameter script:
parameters ac_bottomlevel = H, ac_toplevel = H + ZZYZX
You should also make them Unique in the parameter list, othwerwise changing library parts will behave oddly.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
