ReignBough
"This add-on cannot be validated. Please contact the distributor." error
I have this error on some units (PC). I know that this maybe caused by not having a correct MDID. I have the correct dev ID and MDID since it is okay on my working unit and other units too.
What are the other possible cause (and solution) to this error.
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
1 Solution
Akos Somorjai
You can also check with Dependency Walker (assuming Windows see http://www.dependencywalker.com) to check if you have all the dependencies (DLLs) installed. The easiest way to do that is to copy the add-on beside ARCHICAD.exe, and open that copy in Dependency Walker.
On macOS the
otool -L [add-on-executable]
gives you a similar, though non-hierarchical list.
Best, Akos
Go to post
3 Replies 3
dfintha
Graphisoft Alumni
Graphisoft Alumni
It is caused by failing the MDID validity check.
If you are sure the MDID is correct, check for possible file corruption.
Best regards,
Dénes
Akos Somorjai
On macOS the
Best, Akos
This message is the response to every possible error loading an add-on – it would be better worded as, "something went wrong loading the add-on".
I think Ákos is right in pointing you toward checking dependencies. If another DLL your add-on is linked against is missing or an incompatible version, the add-on won't load and you get this error.
Ralph Wessel BArch
Central Innovation
