Archicad C++ API
replace window with door
Martin Walter
I'd like to replace an element that actually is a window by a door, by changing the used library part.
For replacing library parts window with window or door with door it works perfectly.
But is it possible to change an element from window to door?
My actual code is:
	API_ElementMemo elementMemo;
	GSErrCode errorGetMemo = ACAPI_Element_GetMemo(guidElement, &elementMemo);
	if (errorGetMemo != NoError)
		return false;
	// create element mask
	API_Element elementMask;
	BNZeroMemory(&elementMask, sizeof(API_Element));
	// set to door
	ACAPI_ELEMENT_MASK_SET(elementMask, API_Elem_Head, typeID);
	element.header.typeID = API_DoorID;
	ACAPI_ELEMENT_MASK_SET(elementMask, API_DoorType, openingBase.libInd);
	element.door.openingBase.libInd = iLibPartIndexNew;
	errorChangeParams = ACAPI_Element_ChangeParameters({ element.header.guid }, &element, pElementMemo, &elementMask);
AC22-27, Windows 11, i7-1355U, 32GB RAM, 2TB SSD
I’m sure this ain’t possible as they effectively completely different tools.
Lee Hankins
macOS Sequoia (15.1.1)
Guru
I made a wish regarding the merging of the relevant tools here. If they ever implement this change, it would most likely make your operation possible.
Ling.
