retrieving 3d data from a modle
hey
the api stipulates that the following two function calls, ACAPI_3D_GetNum and ACAPI_3D_GetComponent are used to retrieve the data from archiCAD as meshes. however, it doesn't seem to work. i open an example file and the GetNum call returns zero.
This is my test code:
std::stringstream str;
long              nBody;
GSErrCode         err;
err = ACAPI_3D_GetNum (API_BodyID, &nBody);
str << "API_BodyID:" << "\t\t\t" << nBody << "\n";
::MessageBox(NULL, str.str().c_str(), "AHHAHAHA", MB_OK);
trying to just arbitrarily obtain a 3D object returns no error, but an incorrect object id.
can anyone help me with what i am doing wrong?
thanks a lot
6 Replies 6
yeah, this is an interesting problem. i tried toying with the provided 3D_Test project, and while i can get it to dump the geometry of any object that i click on, it will not iterate through the whole plan and dump everything at once. it too tells me that there are no bodies in the plan. i don't get an error code.
any help would really be appreciated.
Akos Somorjai
The 3D window has to be active, and a valid model is required. Also, the 3D window has to be in shading mode, not in wireframe.
HTH,
Akos
HTH,
Akos
Are there any way to get around this problem? Can't I do this from the addon so the user doesn't have to be bothered?
jmi wrote:
HTH,
Akos
Perhaps 'ACAPI_Element_Get3DInfo' is what you are after?
Ralph Wessel BArch
Central Innovation
I think it should be implemented like this (from 3D_Test example):
short		origSight = 0, planSight;
// we must switch to the 3D Window's sight
planSight = (short) API_PlanSight;
err = ACAPI_3D_SelectSight (&planSight, &origSight);
if (err != NoError) {
	ErrorBeep ("Cannot switch to the 3D sight", err);
	return;
It's not worth answering questions that are years old - after all, the answer might change every year
Ralph Wessel BArch
Central Innovation
