Archicad C++ API
SOLVED!
uchar_t to UniString conversion
Hello everyone,
im struggling a little bit with the the roomName of the API_​ZoneType. It's an array of type GS::uchar_t and i want to convert it to Unistring to export it to an excel sheet with LibXl. Anyone has an idea how this can be done? Thanks in advance!
1 ACCEPTED SOLUTION
Solution
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
You can simply use the operator= or the constructor function of the GS::UniString.
GS::UniString	roomNameUniStr = elem->zone.roomName;
2 REPLIES 2
Solution
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Thanks Tibor! That was easy. 😃
