Very slick! Good tips!
Excellent advice. But what to do if the value in the 3D code is not -1, 0 but -1, 2? The algorithm shown does not work
Hi @nbeyner, thanks for your comment, you are correct. Depending on the source of the model and how the mesh was defined, you may find different edge codes.
I have made a follow up video, covering the case you mention, with a very similar workflow.
Hope it helps!
wOW! @Jaime-airc_digital
How can I add 1000 votes for this "Best Tip" of them all so far?
Thanks for your support @Francois_MCD, very glad you find the tip useful!
This is brilliant! BEST advice! Thanks. Maybe you know a way to make a 2D symbol so that graphic replacements affect it? Is it possible?
Hi @nbeyner, with the previous settings using "project2 3, 270, 3" Graphical overrides will work when using Drafting Fills override:
To get the projected fills to react to cover fills overrides: just use the following settings in the project command :
Thank you! You have model contours on 2D. I have no lines with the described algorithm. Does this depend on the original model or can it be controlled?
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
