Archicad Python API
About automating tasks in Archicad using the Python API.
ID and Properties via Python
benjaminjamesrowley
Hello everyone,
Is there any way to get the information stored in an element's "ID and Properties" field via Python's API?
I tried treating it as any other property and accessing it via either GetBuiltInPropertyId() or GetUserDefinedPropertyId(), but no luck. It doesn't seem to work like "normal" properties.
I found this discussion on the C++ forum, but I can't seem to apply it to Python.
Thanks in advance!
Hi!
It should work with GetBuiltInPropertyID. Where did you get stuck?
Here's a commented example script I adapted from one of my other examples:
#                              0. GENERAL SETUP                               #
from archicad import ACConnection
# Connect to a running Archicad instance
conn = ACConnection.connect()
assert conn, 'Communication Link is not available - timed out'
# Definitions for shorter access to API functionality
acc = conn.commands
act = conn.types
acu = conn.utilities
#                            1. List of Zone GUIDs                            #
# Get all zones from the open Archicad Plan
zoneElems = acc.GetElementsByType('Zone')
# Make a list of Zone GUIDs from the list of zones
# (`.elementId` is a very confusing choice of name for the zone's GUID here.
#  Don't confuse it with the Zones actual Element ID!)
zoneGuids = [zone.elementId for zone in zoneElems]
#                           2. Element IDs of Zones                           #
# Get the ID for the built in property representing the Element Id
elemIdPropId = acu.GetBuiltInPropertyId('General_ElementID')
# Now obtain the actual Element ID of each zone
zoneElementIdValues = acc.GetPropertyValuesOfElements(zoneGuids, [elemIdPropId])
#             3. Ouptut Zone GUIDs and Element IDs of Zones                   #
# Now we iterate over both the zone GUIDs and Element ID property values which
# we obtained in step 2.
for zoneGuid, elemProp in zip(zoneGuids, zoneElementIdValues):
    # The actual property value is a bit nested inside the result of step 2.
    # (Detail: We can assume that there's only one value and thus use the 1st
    #  element with index 0, since we passed only one Property Id to
    #  `GetPropertyValuesOfElements` in step 2).
    print(zoneGuid, elemProp.propertyValues[0].propertyValue.value)
Let me know if you have any questions about it!
Best,
Bernd
Automating Archicad with Add-Ons, GDL-Objects & Python Archi-XT.com
Hi!
acc = conn.commands
act = conn.types
Best,
Bernd
benjaminjamesrowley
Hi Bernd,
Thank you for your quick and detailed reply. I have since had a adjust your script to fit mine, and I'm pleased to say it works perfectly.
The problem was that I didn't know the Build In Property Name was General_ElementID. I ran GetAllPropertyNames() and then looked for "ID and Properties".
Thanks again,
Benjamin
