2024-09-27 10:32 AM
Is it possible to retrieve a property from a wall and insert the value of the property on, for example, doors and windows located in that specific wall with a Python Script or is it a limitation of the Python API or even Archicad?
In this case, we want to get the sound reduction property from a wall and push it onto the door belonging to that wall.
Thanks in advance!
2024-09-27 11:38 AM
This is what I have managed so far.
I have managed to extract the GUID from the element and propery with the value. I would just need to move the value from one GUID to another. The challenge is to know which door is in which wall. Maybe impossible... 🤔
import archicad
from archicad import ACConnection
from typing import List
# Etablera en anslutning till Archicad
conn = ACConnection.connect()
if not conn:
print("Unable to connect to Archicad")
else:
print("Connection established")
# Få kommandoreferenser
acc = conn.commands
act = conn.types
# Steg 1: Hämta alla property-ID:n och filtrera ut den du vill ha
property_name = "6.3 Ljudreduktion"
property_set = "SS 81 73 40:2021"
# Normalisera strängar för att undvika jämförelseproblem
def normalize_string(s):
return s.strip().lower()
normalized_property_name = normalize_string(property_name)
normalized_property_set = normalize_string(property_set)
# Hämta alla properties
all_property_ids = acc.GetAllPropertyIds()
# Filtrera efter property set och property name
target_property_id = None
for prop in all_property_ids:
prop_details = acc.GetDetailsOfProperties([prop])
prop_definition = prop_details[0].propertyDefinition # Hämta property definition
# Jämför nu med 'group.name' för property set
if normalize_string(prop_definition.group.name) == normalized_property_set and normalize_string(prop_definition.name) == normalized_property_name:
target_property_id = prop
break
if not target_property_id:
print(f"Property '{property_name}' under set '{property_set}' not found.")
else:
# Steg 2: Hämta alla element och deras properties
elements = acc.GetAllElements()
for element in elements:
# Extrahera GUID för elementet
element_guid = element.elementId.guid
print(f"Element GUID: {element_guid}")
# Extrahera elementets property-värde för den specifika property
try:
property_values = acc.GetPropertyValuesOfElements([element.elementId], [target_property_id])
if property_values and property_values[0].propertyValues:
for prop in property_values[0].propertyValues:
property_value = prop.propertyValue
print(f" Property Name: {property_name}")
# Skriv ut värdet om det inte är tomt
if isinstance(property_value, act.NormalStringPropertyValue):
if property_value.value:
print(f" Value: {property_value.value}")
else:
print(f" Value is empty for element {element_guid}")
else:
print(f"Unhandled property value type for element {element_guid}")
else:
print("No properties found for this element")
except Exception as e:
print(f"Error fetching properties: {e}")
