Archicad Python API
About automating tasks in Archicad using the Python API.
New Python utility Function
poco2013
Mentor
The Present Python API is quite limited in its Data Access capacity. And there have been many requests for improved functionality, I made up a AddOn to add additional capabilities via the Execute Command Handler. The Handler just adds on to Tibor's previous fine examples.
Added functions are:
Getelem - returns the Guid of the selected element
GetParams - returns all of the AutoText properties available for a element type. - writes to the session report
GetValue - returns any AutoText value available for a element -- Same as AutoText Label
GetProjInfo -returns the list of keys and values for the project information - writes to the report writer.
GetPoint - returns the x & y coordinates of a clicked point - available for element placement
GetSelected - returns the Guid for all elements selected in order of their selection
EDIT: now returns Array of -- [Guid, LayerName, Floor name, Element ID] in order to identify returned elements
SetProjInfo - sets a new value into any Project info property
GetProjvalue - gets the value of a project info property.
EDIT: added function "GetValuefromGuid": Input -- Guid & AutoText Property Name -- Returns Value
Third Release on GitHub.
Hopefully this will provide access for most of requests made here. If you  have an needed function/capability leave it in the comments and I'll see if it is feasible to add on.
I hope that Graphisoft will shortly incorporate all this capability natively into Python without the use of a AddOn.
If you agree that Python should be promptly expanded , you can send a message to Graphisoft by clinking on like on this post??
The video which demos this utility is posted on YouTube:
New Python Utility Functions
The AddOn apx file is posted on the GitHub site listed in the Video description
i would be interested to hear of any applications which are freed up with the additional commands. And a note on performance. I doubt that Python will be very fast, but manual operations should not be a problem.
Gerry
Ady84a
Realy great work!
Do these AddOns "based on the Execute Command Handler" work only in AC25 or also in AC24 ?
I have not tested them, but Probably not. They were compiled with the 25 version of the API development kit and generally are not backward compatible.
Gerry
