Archicad Python API
About automating tasks in Archicad using the Python API.
PYTHON API - Favorites
dushyant
Hello!
Is there a way to obtain the list of folders in the Favorites palette? I saw in the xml of a favorite, there is a <Folder Name="sampleFolderName" /> . So I was wondering if there is any accessibility in the new Python API for this folder name.
I am listing the favorites and really need to access them as per folders in 'Favorites'.
Thank you.
Dushyant Basson
Tibor Lorantfy
Hi Dushyant,
The current version of Python API does not able to retrieve the folderhierarchy of the favorites.
Currently it’s available only via C++ API. The code below draws the hierarchy of the favorites to the Report window, simply call DrawFavoritesTree method.
(Note, the code was written by using AC23 API.)
static GS::UniString DrawLevel (USize level)
       GS::UniString string;
       for (UIndex ii = 0; ii < level; ++ii)
              string += '\t';
       return string;
static GS::UniString DrawItem (const GS::UniString& name, USize level)
       return DrawLevel (level) + name + '\n';
static GS::UniString DrawFolder (const GS::UniString& folderName,
                                                       const GS::HashTable<GS::UniString, GS::Array<GS::UniString>>& subFoldersInFolder,
                                                       const GS::HashTable<GS::UniString, GS::Array<GS::UniString>>& favoritesInFolder,
                                                       USize level = 0)
       GS::UniString string = DrawItem (folderName, level);
       string.Insert (string.GetLength () - 1, " [");
       ++level;
       if (subFoldersInFolder.ContainsKey (folderName)) {
              for (const GS::UniString& subFolder : subFoldersInFolder[folderName]) {
                     string += DrawFolder (subFolder, subFoldersInFolder, favoritesInFolder, level);
       if (favoritesInFolder.ContainsKey (folderName)) {
              for (const GS::UniString& favorite : favoritesInFolder[folderName]) {
                     string += DrawItem (favorite, level);
       string.Insert (string.GetLength () - 1, " ]");
       return string;
static GSErrCode DrawFavoritesTree ()
       API_ToolBoxInfo      toolboxInfo = {};
       GSErrCode            err = NoError;
       err = ACAPI_Environment (APIEnv_GetToolBoxInfoID, &toolboxInfo, (void*)(GS::IntPtr) true);
       if (err != NoError)
              return err;
       // Get all favorites
       GS::HashTable<GS::UniString, GS::Array<GS::UniString>> favoritesInFolder;
       GS::Array<API_FavoriteFolderHierarchy> folders;
       for (Int32 ii = 0; ii < toolboxInfo.nTools; ++ii) {
              const API_ToolBoxItem& toolBoxItem = (*toolboxInfo.data)[ii];
              GS::Array<API_FavoriteFolderHierarchy> foldersForTool;
              GS::Array<GS::UniString> favoriteNames;
              ACAPI_Favorite_GetNum (toolBoxItem.typeID, toolBoxItem.variationID, nullptr, &foldersForTool, &favoriteNames);
              folders.Append (foldersForTool);
              for (UIndex jj = 0; jj < favoriteNames.GetSize (); ++jj) {
                     favoritesInFolder.Retrieve (foldersForTool[jj].GetLast ()).Push (favoriteNames[jj]);
       BMKillHandle ((GSHandle *)&toolboxInfo.data);
       if (folders.IsEmpty ())
              return APIERR_GENERAL;
       // Build tree from favorites
       GS::HashTable<GS::UniString, GS::Array<GS::UniString>> subFoldersInFolder;
       for (const API_FavoriteFolderHierarchy& folderHierarchy : folders) {
              GS::Optional<GS::UniString> parentFolderName;
              for (const GS::UniString& folderName : folderHierarchy) {
                     if (parentFolderName.HasValue ()) {
                           GS::Array<GS::UniString>& subFolders = subFoldersInFolder.Retrieve (parentFolderName.Get ());
                           if (!subFolders.Contains (folderName))
                                  subFolders.Push (folderName);
                     subFoldersInFolder.Retrieve (folderName);
                     parentFolderName = folderName;
       // Sort folders and favorites in tree
       for (GS::Array<GS::UniString>& subFolders : subFoldersInFolder.Values ()) {
              GS::Sort (subFolders.Begin (), subFolders.End ());
       for (GS::Array<GS::UniString>& favorites : favoritesInFolder.Values ()) {
              GS::Sort (favorites.Begin (), favorites.End ());
       // Draw tree into the Report Window:
       const GS::UniString rootFolderName = folders.GetFirst ().GetFirst ();
       ACAPI_WriteReport (DrawFolder (rootFolderName, subFoldersInFolder, favoritesInFolder), false);
       return err;
11 REPLIES 11
Tibor Lorantfy
Hi Dushyant,
              string += '\t';
       return string;
                                                       USize level = 0)
       ++level;
       return string;
       if (err != NoError)
              return err;
       return err;
poco2013
Mentor
In the same vane as above :
I tried compiling the Favorites_Test example and got a huge number of errors -- 973 errors -- basically could not find the standard header files such as: error.h, float.h, correct.h, stdef.h, stdin.h --- etc. etc.
All other examples that I tried compile fine without modification. Obviously something was missed in Favorites_Test. Using Download API Development Kit 23 3006 on Windows 10 with VS 2017
What do I need to fix?
Gerry
MOREH Tamas
Have you installed well the Windows SDK? If yes, you should check the Project properties. Check the VC++ Directories page and the Include Directories row. If you open the edit dialogue of the Include directories you see the paths and you can check them if they are correct.
But please pay attention to the Subject from now on. This is not a Python related question.
poco2013
Mentor
Thanks for the non-response
Gerry
Bit harsh – Tamas gave you some good leads to check out.
Ralph Wessel BArch
Central Innovation
Akos Somorjai
Which edition of VS 2017 did you install? The Community Edition usually requires an additional download of the Windows SDK.
Best, Akos
poco2013
Mentor
Thanks AKOS
I am using the Community 2017 version.
The real problem is that Graphisoft does not advise of the SDK issue. and apparently ?? different examples require different SDKs. -- Almost all other Examples will compile normally out of the box which threw me the "curve"
I finally figured that out. Thanks for the very Professional answer.
Gerry
dushyant
Hi
Does the current Python API release (with AC-24) include anything to access the 'Favorites'?
Tibor wrote:
Hi Dushyant,
              string += '\t';
       return string;
                                                       USize level = 0)
       ++level;
       return string;
       if (err != NoError)
              return err;
       return err;
Tibor Lorantfy
Unfortunately my answer is no. Currently (AC24.3010) the Python API is not able to access any information related to the Favorites.
It's in our backlog, but we haven't started to implement it.
