Archicad Python API
About automating tasks in Archicad using the Python API.
[PYTHON -Tapir} default publiser set path?
Mats Knutsson
What should I write for for the outputPath if I want to use the path set in the Publisher set?
Br,
M
publisherSetName:
 string * minLength:1
outputPath:
 string minLength:1
HP ZBook Fury 15,6 G8. 11gen i7-11800H 2.3GHz. 32 GB RAM. Nvidia RTX A3000 1GB. AC22-27 SWE.
runxel
Hero
Hi Mats, just leave it empty!
To cite the docs:  "Full local or LAN path for publishing. Optional, by default the path set in the settings of the publisher set will be used."
To make your life easier you might enjoy using Perisso, my frontend for Tapir.
It's currently still very much WIP but should be ready for production soon!
runxel
Hero
Thx! I somewhat understood that. I'll have a peek. Need to understand github first. I'm the kind of person that needs to see a youtubevid to understand things nowadays.
What I will do is a "one-click" pdf report about CO2 directly from AC using the python publish plus a py script that runs another py script on the schedule just published to create a nice dashboard style report.
/M
