Archicad Python API
About automating tasks in Archicad using the Python API.
Python in Archicad 27
martin-b
I've just installed AC27 and I'm wondering if Python has not been implemented there yet?
When I try to enable the Python Palette in the Work Environment, the check-in field just does not work. It's not greyed out for me, but when I click on it, nothing happens. It just stays "unchecked".
4 REPLIES 4
Professor Pickle
Similar here. While I can enable python palette in Work Environment the palette is nowhere to be found.
Pushing the boundaries of local time/space continuum since 1972.
Archicad 26 | iMac (Retina 5K, 27-inch, 2017) | 4.2 GHz Quad-Core Intel Core i7 | 24 GB | Radeon Pro 580 8 GB | macOS 12.6
martin-b
I just had a quick look at it again and it seems that it has solved by itself. I was at first looking at AC27 in the demo mode after the installation.
Now that we've set up a licence server for 27, the Python Palette seems to be working.
Marco Milazzo
Ive installed the last update, but isnt working here....
CosminF
I'm facing the same issue. Latest AC 27 Build, latest version of Python.
AC 27, running on Windows 10 Intel(R) Core(TM) i7-9700K CPU64, 3.60GHz, 16GB RAM, Nvidia GeForce GTX1650
