2024-04-23 11:21 AM
So i asked a question yesterday that i worded badly so ill give it another go in hopes of some clarification regarding the Python link.
1. Is it possible to to make Python write in tables?
2. When i try to extract ElementID it gives me the GUID. i dont need the GUID i need the name. example: YV-001
Thanks in advance!
Solved! Go to Solution.
2024-04-23 12:05 PM
1-You can extract value and put them in an excel file. You can't modify an archicad schedule.
2- You need the GUID of the element and the GUID of the property to retrieve a value:
GetPropertyValuesOfElements(elements: List[ElementIdArrayItem], properties: List[PropertyIdArrayItem]) → List[PropertyValuesOrError]
Returns the property values of the elements for the given property.
Parameters:
elements (list of ElementIdArrayItem) – A list of elements.
properties (list of PropertyIdArrayItem) – A list of property identifiers.
Returns:
A list of property value lists.
Return type:
list of PropertyValuesOrError
2024-04-23 12:05 PM
Parameters:
Returns:
Return type:
2024-04-24 10:48 AM
Thanks for the reply @Mathias Jonathan. if you look at my latest post there is more info on what i need to make. and lets say it as it is. its not making. its very frustrating.
