Archicad Python API
About automating tasks in Archicad using the Python API.
Retrieve all classifications item with python
Hello everyone.
I'm pretty new to python, but I've managed to make a few scripts.
I am working on a script with a graphical interface, and I would like to be able to propose to select a classification in a Tkinter treeview style interface (keep the hierarchical system).
I've managed to retrieve the first and second levels of classifications, but my system is pretty basic in terms of code: I don't know, for example, how to find out the depth of the list retrieved by archicad.
Basically: how can I retrieve a hierarchical list with only the classification names?
My attempt (for the first and second levels):
from archicad import ACConnection
conn = ACConnection.connect()
acc = conn.commands
act = conn.types
acu = conn.utilities
chooseClassification = acc.GetAllClassificationSystems()
classifications = acc.GetAllClassificationsInSystem(
    chooseClassification[0].classificationSystemId)
nbEnfants =0
nbEnfants2 =0
for classification in classifications:
    print("      "+classification.classificationItem.id + "    " +
          str(len(classification.classificationItem.children))+" children")
    nbEnfants +=len(classification.classificationItem.children)
    for subelements in classification.classificationItem.children:
        try:
            print("                " + subelements.classificationItem.id + "   " +
                  str(len(subelements.classificationItem.children))+" children")
            nbEnfants2 +=len(subelements.classificationItem.children)
        except TypeError:
            print("                " + subelements.classificationItem.id)
print(nbEnfants)
print(nbEnfants2)
Archicad 27 - GDL - PYTHON
poco2013
Mentor
Not sure I can be of any help --But to retrieve the Classifications tree you need to use recursion. i wrote a classification interface for grasshopper which uses the Json interface and not the built in Python interface. Attached is a Demo Script - You would have to translate to the native Python interface which does not need Json.
Note that the two native classifications in Archicad use different Ids and naming convention. i assume you are interested in the Graphisoft default.
import json
import  urllib.request as rb
#request = rb.Request('http://localhost:19723')
request = 'http://localhost:19723'
response = rb.urlopen(request,json.dumps({"command":"API.GetAllClassificationSystems"}).encode('UTF-8'))
results = json.loads(response.read())
result = results['result']['classificationSystems'][0]['classificationSystemId']['guid']
response.close()
response = rb.urlopen(request,json.dumps({"command":"API.GetAllClassificationsInSystem",
"parameters": {"classificationSystemId": {"guid": result }}}).encode('UTF-8'))
response.close()
seed =results['result']['classificationItems']
output = []
level = 0
def get_ids(seed,kids = 0 ):
    global level
    level += 1
    for item in seed:
        output.append( '   '*(level-1) +  item['classificationItem']['id'])
        if kids >0:
            kids -= 1
        if 'children' in item['classificationItem'].keys():
            depth = len(item['classificationItem']['children'])
            get_ids(item['classificationItem']['children'], kids = depth)
        else:
            if kids == 0:
                pass # Debug only
    level -= 1
get_ids(seed, kids = 0 )
for x in output:
        print(x)
Gerry
poco2013
Mentor
import json
response.close()
response.close()
output = []
level = 0
    global level
    level += 1
    for item in seed:
        if kids >0:
            kids -= 1
        else:
            if kids == 0:
                pass # Debug only
    level -= 1
for x in output:
        print(x)
Gerry
It worked well, thanks a lot!
here is my code (it's not clean, but it seems to work!)
acc = conn.commands
act = conn.types
seed = classifications
output = []
level = 0
def get_ids(seed, kids=0):
    global level
    level += 1
    for item in seed:
        output.append('   '*(level-1) +
                      item.classificationItem.id + " (level " + str(level) + ")")
        if kids > 0:
            kids -= 1
        try:
            get_ids(item.classificationItem.children,
                    kids=len(item.classificationItem.children))
        except TypeError:
            pass  # Debug only
    level -= 1
for x in output:
    print(x)
