Unused layer combinations
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2025-04-28 10:50 AM - edited 2025-04-28 10:51 AM
Hi All
Is there a way to find unused layer combinations?
How can I check which layer combo is used for View Map item?
I don't see any command I could use.
Thank you
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-04-29 09:29 PM
Hello Piotr,
The 1.1.4. relese of the Tapir archicad addon has just intruduced the GetViewSettings command that returns the name of the associated layer combination for each NavigatorItemId.
There seams to be something off with the documentation for this command, so I'll paste the schema from the source here:
"name": "GetViewSettings",
"version": "1.1.4",
"description": "Gets the view settings of navigator items",
"inputScheme": {
"type": "object",
"properties": {
"navigatorItemIds": {
"$ref": "#/NavigatorItemIds"
"additionalProperties": false,
"required": [
"navigatorItemIds"
"outputScheme": {
"type": "object",
"properties": {
"viewSettings": {
"type": "array",
"item": {
"type": "object",
"description": "The settings of a navigator view or an error.",
"oneOf": [
"$ref": "#/ViewSettings"
"$ref": "#/ErrorItem"
"required": [
"viewSettings"
"ViewSettings": {
"type": "object",
"description": "The settings of a navigator view",
"properties": {
"modelViewOptions": {
"type": "string",
"description": "The name of the model view options. If empty, the view has custom model view options."
"layerCombination": {
"type": "string",
"description": "The name of the layer combination. If empty, the view has custom layer combination."
"required": []
I think the official JSON commands should cover the rest (API.GetNavigatorItemTree can get you the NavigatorId-s of all views)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-04-29 09:29 PM
Hello Piotr,
"version": "1.1.4",
"inputScheme": {
"type": "object",
"properties": {
"required": [
"navigatorItemIds"
"outputScheme": {
"type": "object",
"properties": {
"viewSettings": {
"type": "array",
"item": {
"type": "object",
"oneOf": [
"required": [
"viewSettings"
"ViewSettings": {
"type": "object",
"properties": {
"type": "string",
"type": "string",
"required": []
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-04-29 11:24 PM
Thank you SzamosiMate, that looks promising. I'll check it next week.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-05-16 06:11 PM
Thank you again — GetViewSettings command worked well. Also, thanks to every Tapir contributor.
Do you think it's possible to check whether a layer is visible in the view when using a custom layer combo?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-05-17 07:51 AM
@Piotr Walerysiak Have this worked for you?
Civil Engineer, Enviromental Design MSc., BIM Manager for BS ArhitectsVR
Company or personal website
Archicad 27. Windows 11. Intel Xeon 2699x2,64 GB RAM, Nvidia 3080Ti. 2 Monitors.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-05-17 01:29 PM
Currently GetViewSettings does not return this information, but it is avalible from the C++ API, so it should not be too difficult to change the command to include this informaton.
If you'd like to use it in a workflow, please ask for it on the Tapir Discord, or open an Issue on Github. (https://github.com/ENZYME-APD/tapir-archicad-automation)
Thinking about it, with this, and a possible future CreateLayerCombinations Command you could scan all views, and for all "custom" views find the corresponding layer combination and set it for the view, or if none exist create one in a separate folder that the user can check and decide what to do with it.
That seams like a wortwhile thing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2025-05-19 10:24 AM
Yes, that worked. Here's my code:
from archicad import ACConnection
conn = ACConnection.connect()
assert conn
acc = conn.commands
act = conn.types
acu = conn.utilities
response = acc.ExecuteAddOnCommand (act.AddOnCommandId ('TapirCommand', 'GetAddOnVersion'))
print (f'Tapir {response}')
########## GetLayerCombinationList ##########
layerComboAttr = acc.GetLayerCombinationAttributes(acc.GetAttributesByType("LayerCombination"))
layerComboNameList = [layercombolists.layerCombinationAttribute.name for layercombolists in layerComboAttr]
######## Get ViewMapTree and ViewGuids ########
def isViewNavigatorItem(item : act.NavigatorItem):
return item.type != None and item.type != 'FolderItem'
viewMapTree = acc.GetNavigatorItemTree(act.NavigatorTreeId('ViewMap'))
viewmap = acu.FindInNavigatorItemTree(viewMapTree.rootItem, isViewNavigatorItem)
viewGuids = [{'navigatorItemId': viewmaps.navigatorItemId.to_dict()} for viewmaps in viewmap]
######### ViewLayerCombinationList #########
### Get View Settings (Tapir command)
viewSettings = acc.ExecuteAddOnCommand(
act.AddOnCommandId('TapirCommand', 'GetViewSettings'),
{"navigatorItemIds": viewGuids }
viewSettings = viewSettings.get('viewSettings')
allViewSettingsLayerComboNameList = []
for viewSetting in viewSettings:
if viewSetting.get('layerCombination') != None:
allViewSettingsLayerComboNameList.append(viewSetting.get('layerCombination'))
### Filter ViewLayerCombinationNames
usedLayerComboList = []
for usedLayerCombo in allViewSettingsLayerComboNameList:
if not usedLayerCombo in usedLayerComboList:
usedLayerComboList.append(usedLayerCombo)
######### UnusedLayerCombinationList #########
unusedLayerComboList = []
for layerCombo in layerComboNameList:
if not layerCombo in usedLayerComboList:
unusedLayerComboList.append(layerCombo)
unusedLayerComboList.sort()
unusedLayerComboListStr = ""
for unusedLayerCombo in unusedLayerComboList:
unusedLayerComboListStr += f'{unusedLayerCombo}\n'
print(f'\nUnused Layer Combinations:\n{unusedLayerComboListStr}')
