‎2023-04-10 07:10 PM
Does anyone have an example python script that calls / runs an add-on?
‎2023-04-10 07:50 PM
The Python API has no ability to call and run a C++ AddOn.
A Python script cam only communicate with a AddOn through a builtin function called -- ExecuteAddOnCommand - by passing certain parameters. However the AddOn must have pre-programmed and registered a class to received the request. That class inherits from the AddOnCommand class.
An example of the Python function can be found on the Archicad PyPi site.
A typical example of the required C++ API class could be found on Tibor's old example site on GitHub.
‎2023-04-10 08:30 PM
Hi Gerry, TY for the speedy response! I will check out the links you provide. Very helpful!
