‎2023-02-01 09:16 AM
Hi.
do anybody know if it's possible to exclude elements in an excel export with python?
if so will you care to show/explain.
Solved! Go to Solution.
‎2023-02-01 02:04 PM
If I understand you, if you are using a Python script to gather data, of course, you can exclude any properties you don't want. Just use a python filter, to filter the data to whatever you want. There are many instructional videos on YouTube on this subject.
‎2023-02-01 01:25 PM
Neither the Python API or the C++ API have any ability to address or modify the interactive schedules. This appears to be a Graphisoft Philosophy. -- Don't know why??
You could use a Python script to directly gather the element attributes and place them in a excel spreadsheet. Python scripts have that ability.
But a better approach may be to just export the schedule to excel and delete or ignore the properties you don't need. OR directly modify the schedule criteria.
‎2023-02-01 01:37 PM
i see.
i'm currently using python pallet in archicad and export lets see window object with element id, height and width parameters, and wounder if i could exclude exsample every windpow with element id W-01. but i guess this is not possible...
