ata1993
BIMcloud API extracting project data
I am currently looking for possibilities to extract data on all created projects from the vbim server using the BIMcloud API.
Regular queries and storage of the information should take place.
However, I am a bit stuck, I am using the repository with the BIMcloud API specification.
https://github.com/GRAPHISOFT/bimcloud-api
My approach is as follows, I have the URL for the server, as well as username and password.
With the ManagerAPI class I create a session with create_session() and get the session_id as return value. Which I then use in the get_resource() function. But from the get_resource() function, I don't get all the data from the server.
Or if I knew how to get the data for a project, I could iterate over all projects.
I would be very happy about some food for thought?
2 Solutions
Noemi Balogh
Hi @ata1993.
Unfortunately what you want to achieve with the publicly available BIMcloud API is not possible. Project data are handled by our private APIs and received data from these APIs can be handled by Archicad only. Our publicly available API offers services for uploading and downloading files from BIMcloud.
A workaround tip could be to use the Archicad API, because it might can get some data once you managed to connect and log in to a BIMcloud, but if you ask me, this sounds really cumbersome to be the solution.
Kind regards,
Noémi
Noémi Balogh
Senior Community Expert, Admin
Go to post
leilei
HI.
If you want to get all project information, you can try calling like this GET:http://ip:22000/management/latest/get-projects?session-id=xxxxx
If you want to get all project information, you can try calling like this GET:http://ip:22000/management/latest/get-project?session-id=xxxxx &project-id=xxxxx
Go to post
4 Replies 4
Noemi Balogh
Hi @ata1993.
Kind regards,
Noémi
Noémi Balogh
leilei
HI.
ata1993
Hello Noemi Balogh,
thank you very much for responding so quickly. After reading your message, we dropped our approach with the BIMcloud API.
And we took an approach via GET request using Curl and have now successfully extracted all the information about the projects.
Kind regards,
Ata
ata1993
Hi leilei,
Thank you for your comment regarding GET requests using Curl.
We have used a similar query:
http://vbimmanager:20000/management/client/get-resources-by-criterion?session-id=xxxx
to extract all possible information from the vbimmanger.
We will try your get methods as well
Kind regards,
Ata
