BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
BIMx Viewer Plan View
Hello,
I am using a BIMx file in Graphisoft BIMx Viewer of a home and the site site/property and was wondering if there is a way to use it to show a direct plan view looking down from above. Thus far I have just been able to fly up and look down and when I look down the site objects are viewed in perspective instead of in plan. Is it possible to do and if so how? Thanks in advance for any suggestions.
Sean
1 REPLY 1
Marc H
Did you include a drawing set in your BIMx publishing set? You can include any of the plans (e.g., furniture), sections, and other documents you would in a PDF output. Each will also have a link to and from the model.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC27 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Sonoma OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
