BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
BimX on PC - High resolution?
Hi all
We're wanting to use BimX for client presentations on the big 4K screen.
Unfortunately it looks awful in the current resolution. All edges ragged.
What can be done about this?
Hello jlcstocker,
Windows and MacOS devices are not the best way to present a BimX.
The best way to present a BimX is on a iPad Pro 13" in your client hand.
You are able to use a Apple TV to get a mirroring of your iPad screen without cable or you can use a câble to link your iPad to a 4K TV.
With your project in their hands, your client will no longer need 4K to be seduced.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
Minh Nguyen
Hi jlcstocker,
Thank you for reporting the issue and I am sorry about the experience!
Could you be a bit more specific on the issue that you are having:
- Which BIMx application and platform are you using?
- How do you show/transmit the BIMx model to 4K screen
- Can you make a screenshot on how awful does it look on the screen?
Looking forward to hearing from you soon!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
