BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
BimX viewing problem from ArchiCAD 17
ryancjw
Hi I am not sure if anyone has encountered the same problem. A project was originally made in AC16 recently migrated to AC17, and exported as a BimX model. While navigating around the surfaces started to 'split' and showing objects and walls behind, as if the walls become semi-transparent.
- Please see attached image
I am wondering if this is due to the building material conversion in AC17.
Ryan Wu
Desktop: DELL Vostro 460, Intel i7-2600 8GB RAM
AMD Radeon HD6670
Windows 7 Professional 64 SP1
Laptop: ASUS 56V, Intel i7 3610QM 8GB
NVIDIA GeForce GT 650M
Windows 7 Home Premium 64 SP1
5 REPLIES 5
There is no image attached.
ryancjw
Apology no attachment previously.
After the watching the webinar on Migrating to AC17, I think I need to do a proper clean up of the model and building materials and see if it improves.
Ryan Wu
AMD Radeon HD6670
I haven't experienced this problem so probably can't be of much help.
Have you tried updating your video card drivers - the first thing I always check when things don't appear as they should.
Also you mention the job was converted to 17 but you show it being saved in version 16 build 3827.
Is your problem in 17 or 16?
ryancjw
Barry,
All video cards drivers are up to date.
Yes the job was documented in AC16 recently migrated to AC17.
We started to experience to BIMx problem from BIMx17.
So I did a test to save it back to AC16 and export to BIMx again and got the same results.
Ryan Wu
AMD Radeon HD6670
Marton Kiss
Ryan,
our engineering is currently working on a solution for a really similar issue. I am going to PM you a link, where you can upload the project if you are alright with that. For our development every such example projects are extremely useful to make sure they take into account all possible situations.
Marton
Marton Kiss
Chief Product Officer
GRAPHISOFT
