Is there a way to publish all-white BIMx model?
to publish an all white bimx model without adjusting all the model materials?
Maybe through the publishing process?
Thanks
3 Replies 3
In your BIMx app go into OPTIONS then SHADING.
There you will have options for 'Metal' and 'Black & White' among others.
I know there is also an option for "Metal' on the desktop viewer as well - not sure about others.
I found that option on the bim x app however the option to select balck and white is grayed out. I can not select that feature.
Thanks
Maybe it has something to do with the way they were saved - but I am not sure what that could be.
The GS demo files have 5 shading options - all available.
I notice in models I have created that 'Realistic' and 'Black & White' are greyed out.
A 6th one appears - 'Stored in model' and that is active by default.
I don't have time to investigate it right now - does anyone else have the answer?
