Real-life movement speed?
Is there any source for the real-life equivalent of the speed slider values in the viewer settings?
I was thinking of just exporting some 100 or 500 m 'track' and running it with w and Shift-w, but then I wondered whether the values might vary with model dimensions so that one would gave to check at least two models, then I wondered whether hitting front and side simultaneously would move you diagonally at the given speed or at 1.4142, which would need to be tested too, so I thought I should rather first ask.
I want to make a demo moving at the real-life speeds of a car and a pedestrian.
0 Replies 0
