Walk through objects like doors
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2020-03-24
09:40 AM
2023-05-09
05:21 PM
Noemi Balogh
2020-03-24
09:40 AM
Is there a setting for objects or other archicad elements to allow walk in BIMX through them like it happens with doors? Classifications for example seams doesn't work.
For example if I put picture images objects like plants using walls.
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
Solved! Go to Solution.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-03-25 03:50 AM
2020-03-25
03:50 AM
It is the opening (or more accurately the WALLHOLE command in the GDL script) that you are walking through.
That is why you can only walk through doors and windows.
Unless you turn fly mode on and then you can pass through anything.
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-03-25 03:50 AM
2020-03-25
03:50 AM
