4hotshoes
What is the tallest a step can be and still get up in Bimx viewer?
Sometimes you can get stuck and can't move on if a step is too tall. Is there a way to make this work? what are step height limitations?
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
I am not sure exactly what the step limit is but the space bar will allow you to jump up most steps.
Or of course just turn on fly mode.
Pressing Y or PageUp will turn on fly mode and lift you vertically.
H or PageDown will lower you.
Then move forward over a floor and press F to turn fly mode off and continue on your way.
This is in the desktop viewer, I assume there are similar controls in the mobile app.
Stress Co_
If you don't want to switch to fly or Jump (as Barry noted), you could always
add a few slabs as steps. Set them to a Glass material (with transmittance set to 100).
i.e., make them invisible.
Marc Corney, Architect
Red Canoe Architecture, P. A.
