Brett Brown
White Surfaces in Bimx
Hi all, Why am I getting all white surfaces in the 3D model coming out as light gray in the Hyper model? Both the 3D model and Hyper model use the internal /open GL engine so why are they not the same?
Earlier versions of Bimx use to open in the Hyper model, now it opens in the 3D model and you have to select the "browse hyper model" then "open 3D model" when I only have the one view. Is this the normal way now?
Any quick setting to stop all the weird shadows created at the intersection walls to ceilings and sometimes furniture sitting close to the walls?
Cheers
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
12 Replies 12
are you rendering with global illumination turned on? can you attach a screenshot?
Brett Brown
Yes I am rendering with Global Illumination turned on. See attached before and after
This new forum was to change max size of attachments from 500kb to 5mb. seems it is still set to 500kb. Mine are 900kb so won't attach. Could moderator please fix, cheers
Maybe there is a problem with the dimensions of the image (number of pixels, maximum is 1920x1200), not the file size.
Brett Brown
If I click the error triangle after the file name it states the file has to be under 500kb, files are under the pixel size limit
This is strange, I have checked in the Administration part of the forum and the maximum file size for any attachment is set to 5 MB, which is a global setting. I will investigate.
Can you show a screenshot that shows the error message that you get when you try to attach that file?
Brett Brown
Here you go
Thanks. I will report back when we found some answers.
Brett, can you now try to attach this same image to a post?
The forum database guy made some modifications to attachment-related settings.
I would like to see if it helped in your case or not.
