BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
can't load the bimx add on
please see the attached file. how can i fix this?
1 REPLY 1
Re-install Archicad or you could try running the latest hotfix if you don't already have it installed (I think it is build 8000 for version 17).
It is not a separate add-on so you will have to re-install/update.
