2025-06-11 04:10 AM
hii
I’m testing BIMx for presentations for the first time and I think it’s super cool! However, I noticed that the layouts (floor plans, renderings, and elevations) are showing up in poor quality and with off colors in the BIMx model.
I’m on a Mac, so I used the print settings workaround to save the layouts as a PDF, and there the quality and colors were flawless. But when I save it as bimx hyper model, they appear slightly blurred and darker colors.
Since one of the main goals is to use BIMx for presentations, I’m a bit confused about the poor layout quality.
Is there a way to export or save the layouts in higher quality into the BIMx Hyper-model?
2025-10-16 04:33 PM
Hi Benjamin
thank you! We will likely step into the archicad studio, the issue is fixed there as well? Very happy about it
2025-10-17 10:30 AM
@Benjamin Dani I work with DDScad and overall adding additional PDFs may be option. When it comes to interaction with site, especially on small / medium tasks, possibility to giving access to freshest set of drawing is essential. There is always a laptop / PC onsite. So uncompressed PDF's are essential.
In general you advertised in ~2022 Archicad tight workflow and tight integration with BIMx, content from marketing videos is still impossible to achieve. Releasing MEP hyper model without possibility to cut / disable / hide certain walls makes it unusable in practice. There is also no connection between floorplans and models. I can be OK with it but after all even essential feature like batch transferring of PDFs to site is also not that well done. There is a publisher set feature, designed especially to BIMx integration (there is no other option for batch exporting of PDFs!) and it's killed by degrading of quality.
2026-02-22 09:33 PM
still unsolved and layouts in pdf's looks like piece of garbage
2026-03-25 08:28 AM
hello, how you can mark this topic as solved?
2026-03-25 10:00 PM
I have reviewed the post marked as a solution and decided to unmark it as it did not offer any solution to the starting post of the topic.
2026-03-26 03:48 AM
regarding to bimx also, is it required to be signed in to view the files in the app?
2026-03-27 08:10 AM
Thank you.
How this quality can be even satisfying anyone? Smallest font from this title block is finally 2,5mm (scaled down by 0,5 instead by upscaling 1:100 part model).
It's a joke, isn't it?
2026-03-27 08:12 AM
I should wish for something that should be essential in AEC software? Are you kidding or what 🙂
2026-03-31 06:27 PM
Today on the BIMx app (android), I've noticed all the layouts are pixelated and illegible. Complete unusable garbage. On macOS and iOS, the same layouts read fine, so it's not a file issue. And the issue exists on both new BIMx files (created today) and old ones (that have been on the phone for 18+ months). I use BIMx regularly on my phone (Pixel 9 pro) and have never seen this issue before.
2026-04-07 10:56 AM
Guys, please post a wish on the Wishlist. That is the only way to find out how much support this wish has, and then that can be forwarded to Graphisoft for consideraton:
https://community.graphisoft.com/t5/Wishlist/idb-p/wishlist
