SOLVED!
Door schedule - Sliding door arrow in wrong direction
I've made a door schedule including sliding doors - for some reason the opening arrows are correct in the elevation, but not in plan. See screenshots, I've marked an example in red. All the arrows are automatically generated. Any advice here?
1 ACCEPTED SOLUTION
Solution
I would say that your plan view is correct (in the schedule) and the elevation is not - well it is because you have told it to show the elevation from the 'Opening Side'.
I think you have placed the door incorrectly on the plan however.
You have placed the opening side on the inside of the room.
First click is to choose the wall where you want the door/window.
The second click gives you the 'outside' and orientation of the door (left/right).
1 REPLY 1
Solution
