Collaborate forum
Importing fonts
I have a new true type font I'd like to import, but can't seem to find out where to do it...can anyone help?
2 REPLIES 2
Gerald Hoffman
It is good to put your operating system in a signature as it is probably a different procedure. If you are on Windows you need to open your Control Panel and go to the Fonts folder and chose menu command Add New Font under File Menu. Find the font in the browser window in the bottom half of the dialogue box and it will appear in the upper box when you find a font. Select the font and make sure the tick box is selected at the bottom which says "Copy fonts to fonts folder"
Gerald
"The simplification of anything is always sensational" GKC
AC 25-4013 USA, CadImage Tools
2019 MacBook Pro 16" w/ AMD Radeon Pro 5600M GPU
OS X 11.6
2.4 Ghz 8 core i9, 64 GB RAM
27" LG 5K Monitor
Thanks..that worked perfectly!! Knew it would be easy once someone opened the door...
