Otavio A
AC29 Default font issues
Hello, I’m starting the process of recreating our office template in Archicad 29 (we were using version 27). However, when I started editing the properties, I noticed that the Property Editor is using a font that I don’t even have installed on my computer anymore, and it’s unreadable font at this size. Is this a bug? Is there a way to fix it?
A screenshot of the issue:
5 Replies 5
Aaron Bourgoin
Can you reproduce the error on a different machine? If not, then may I suggest you uninstall and re-install AC on your computer.
I'm no longer. much of a Windows user, but it might be  corrupted registy entry. ???
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 30 / AC29.2.1 COLLABORATE AC30.0.0 COLLABORATE
Rhino 8.36 Mac
MacOS Tahoe 26.6.2
Otavio A
I couldnt reproduce the error on another machine, but i tried your suggestion and it didnt work...
i even tried to change the fonts in the regedit in windows and could change every single font in the program, except for the one in the expression edditor :c
runxel
That's an old bug that GS has never bothered to fix. No clue why it is so difficult, but if I remember correctly is was deemed an "impossible task" 😄
Only option is to find that font and uninstall it (and hope a better one is picked).
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Otavio A
i did find the font, first i thought it was already uninstalled, but there she was.. so i did unistall it but the problem persisted.
i even unistalled AC, reboot the machine and installed it again... no succes unfortunately
runxel
It was installed again automatically? That's weird. Never seen this. Do you have a guess which software you have installed that does this?
The only option now I can think of is to delete the file again, but before you copy the file name. Then you make a soft link to a "good" font, like Arial, and rename the link.
Or, as you have tried, using the Registry. I think it supports Font Substitution, which should work everywhere.
