Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Problem publishing Layout as DWG--No Drawings
I am using Archicad/Plotmaker 9. I try to publish a layout to DWG, and the layout I select shows no placed drawings in the Preview, only the usual plotmaker placeholder. When I drag the layout to the publishing window and select it, same thing, no drawings in the preview. Texts placed directly from Plotmaker DO show in the preview. When I publish, sure enough, no drawings in the DWG file generated, but the Plotmaker texts DO show up. I have tried very combination of paper/model space options etc. Any ideas? Thanks
0 REPLIES 0
