Revit Addin blocks Revit starting up
I've installed the latest ArchiCAD IFC Revit Addin and it now takes 71/2 minutes for Revit to start (I timed it - 4 times). Normally it takes 18 seconds (I also timed that).
Latest open source IFC Export/Import Revit Addin is also installed (15.3.0.1)
Revit build: 20150511_0715(x64).
The addin works once Revit has opened, but we really can't use it in its current state.
2 REPLIES 2
Just tested on Revit build: 20150704_0715(x64) - Update Release 9.
Still 7 1/2 minutes.
Also tested on other computers with Revit 2015. Some just never get to open Revit.
Buggy.
Katalin Borszeki
Hi, this issue (#194637 in our DataBase) is already fixed, and the updated version of the Add-in is going to be released soon! Please follow our website for the exact rollout.
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
Learn and get certified!
