Zones
Hi
Many time i try the squedule list with zones i experience problem in the wall surface calculation.
The reference line on the wall has to be perfectly lined up with the zoneline fore it to give nearly accurate calculation. Somehow, even then.., i experience a lot of different values on the wallsurfaces for exact same zones.
I spend hours trying to find the problem and now steel have some small variance. There most be a better way to calculate wallsurfaces.
Is there no way to calculate the vertical surface of the actual zone rather than nearby wall calculation system?
0 REPLIES 0
