object subtypes / IFC / predefined rules
Alex Moruzzi
When creating an object, I understand we should define a subtype that will apply predefined parameters that are aimed to give facility management structure to the information model.
I do also understand that only some very general IFC parameters are ruled out by this subtype selection ...
I understand predefined rules do not affect the IFC parameters in my object.
Well, I guess I would like the subtype and predefined rules to kind of "input" some IFC informations directly... Is that possible ?
I also understand some of the IFC configuration schemes are hidden because they are "fundamentals"...
Is it possible to look at the "hidden" IFC configuration schemes someway ?
Any input would be welcome.
Is someone aware of where I could have additional information on the gdl commandscript : ifc_subtype ?
Archicad 19 - OSX10.10 - MBP early 2011 16G/ssd
2 REPLIES 2
Alex Moruzzi
Alex Moruzzi
Found some information at
http://helpcenter.graphisoft.com/guides/archicad-18-int-reference-guide/interoperability/file-handli...
Sad it writes Archicad 18 in the html folder....
Learn and get certified!
