3DS objects with blank 3D script
Tendenz
Hi guys
I've been converting 3D objects from DWG to 3DS in Rhino, to be able to have different materials on the objects. Somehow I can't get that to work on the DWG-objects.
Anyhow, lately, when exporting to 3DS from Rhino, and then importing to ArchiCAD, the object opens with a blank 3D-script, and are of course useless. If I open the same file in Rhino again, it seems fine.
Anyone had this problem before? Any useful hints? I'm desperate here...
Thanks!
iMac OS X 11.6
2,3 GHz Intel Core i9, 16 GB 2667 MHz DDR4
ArchiCAD 25
1 REPLY 1
Tendenz
No one?
The 3DS-files I make in Rhino make the roundtrip (export from Rhino, import to Rhino) just fine, so I don't know if this is an ArchiCAD issue all of a sudden?
iMac OS X 11.6
ArchiCAD 25
