3d model for energy analysis
has anyone on the forum used an Archicad model w/ Green Building Studio or Ecotect for energy analysis?? Whatever program my Mechanical engineer is using he is unable to import my model. My building is complex.I am trying to keep them from having to re-make the model. Any experience, info, ideas or suggestions would be most appreciated.
win xp sp2
ArchiCAD11 1114 us full
6 Replies 6
Erika Epstein
Cary,
There are many here willing to help, but we need more information. Please include your version of archicad and platform in your profile as others do. This is important as each version of archicad doesn't always work the same way.
For this specific problem we will also need to know the your engineer's program and its version.
Welcome to the forum!
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
thanks for your suggestion
Cary
win xp sp2
ArchiCAD 11 1114 USA FULL
What file-format does this energy-software require when import?
Ralph Wessel
As others have noted, it would help to know what software your engineer is working with. The add-on for the Green Building Studio exports gbXML, which may be sufficient if their software imports it.
Otherwise, you could run your model through the GBS service and re-export the model as a DOE-2 file or EnergyPlus file. There is a reasonable high probability that one of these formats will suit your engineer. To register for the add-on and GBS service, start at http://www.greenbuildingstudio.com/default.aspx
Ralph Wessel BArch
Central Innovation
Ralph thanks for the GBS info....I was not aware that they would provide a DOE2 file form their model analysis. I will look into this.
Cheers, Cary
aahatimo
any news on the energy analysis front and ac v11 or 12?
or anyone out there that can take an ac model and do heat loss / solar gain calcs from an ac model?
i am not having luck getting into autodesk's gbs site, plus site says ac plugin is not available.
thanks!
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
