And here I am.
Really strange, that bug (BTW a very silly bug!) is there till the first version of ArchiForma.
Anyway the bug occurs just if you use a fill to define the revolve profile... that means most of our users don't use the Revolve tool or they use it by defining the profiles with a polyline.
Anyway, just substitute the original AForma_REVOLVE.gsm object in your ArchiForma library with the new object I'm attaching this post and everything will start to work as it should.
Thank you again for your help
Friendly
Fabrizio
P.S. of course the objects saved ad you did should work only if they have been saved as GDL and not binary. They will call the main macro that now is correct so they also will be correct.
	Fabrizio Diodati
