3ds add-on not working in archicad15
Hey,
I have recently upgraded to archicad 15. However, the 3ds add-on that allows one to import 3ds files doesn't seem to function properly. It worked flawlessly in version 14 and 13. Does anyone else have this same problem? Or does anyone have a solution?
1 REPLY 1
Works normally for me on Mac.
When you post a question like this, you need to post what your OS is - and if Windows, if you are 32 or 64 bit, etc, etc... ... and describe WHAT isn't working. 😉
Did you apply the hotfix to 15 after installing the ads plug-in? If not, apply the hotfix again just in case the 3ds add-on that you downloaded is not up-to-date.
One of the forum moderators
